PXI
current sensing of akm servo motor using labview
I am using kollmorgan servo motor(AKM-33H-ANCNC-00) WITH AKD ETHERCAT DRIVE 0606.and this is connected with PXI-7350 . i want to measure current drawn by servo motor for different different loads. i checked this thing with kollmorgan workbench by giving a command IL.FB into its  terminal .but i want to perform this thing with labview. please help me to do the same!!!
  hitendra
(5,881 Views)
I also facing this problem. but it can be possible using Telnet blocks. using drive ip address we can take current vale. use il.fb command for it
(4,169 Views)
