PXI
data clock x2 in FlexRIO 5764?
Hi there
I want to do some raw data processing in 5764 at 250MHz, but the data clock is running at 125MHz, I was wondering what kind of data will I get if I want to read AI 0 Data N-x?
Will this system update all channels at 125MHz even if I'm reading at 250MHz or update half channels at 250MHz? If they do update at 250MHz, where can I found some details about how it works?
Thanks!
(1,115 Views)
Check the shipping example for the 5764.
The 5764 samples data at 1 Gigasample/sec per channel.  The data clock rate is 125 MHz which means that each cycle gives you 8 samples from each channel.
The data clock x2 is provided because some DSP needs a x1 clock and x2 clock.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,109 Views)
Thanks for your reply, by the way, your book on LVFPGA provides really useful insights, I love it very much!
Back to the problem, I did check the shipping example, but not only I couldn't found useful info on how the 8 elements are updated (update 4 elements on each 250MHz clock? if so which order do them update; or update 8 elements every two ticks on 250MHz? if that is the case, which tick do these data update?). I also found it hard to understand, the shipping 5764 example host VI simply doesn't even call the FPGA bitfile, if I did tweak the default FPGA, and compiled it, I can not see any difference with shipping host VI, I don't understand how that comes...
(1,072 Views)
Thank you for the kind words about the book.
In the shipping example's FPGA code the \instr.lib\FlexRIO\API\FPGA\v1\IO\NI5764\5764 AI Channels.vi VI is being called.  This shows how 8 samples are being read per clock cycle.
Acquisition is run at the data clock rate, not at the data clock x2 rate.
ALE Consultants
(1,067 Views)
