PXI
different real-time version problem
My PC uses Labview version is labview 2015 and also labview real-time 15.1.
I have the hardware  PXIe-1082 chassis , PXIe-8102 controller , and PXI-7350 card.
Now, here is the problem that the controller shows it is labview real-time 11.0.
I try to connect but it shows :
Denying access, the version of labview running on the terminal is different from the version of labview running on the host computer. For real-time terminals, you can check the version number and reinstall the real-time software through MAX.
Can I update the real-time version in controller ?
And also NI-MAX in my PC can't recognize PXI system.
How can I do?
Message 1 of 1
(1,735 Views)
