Home
Community
Discussion Forums
Most Active Hardware Boards
PXI
Topic
PXI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
does PXI-6713 have a 50 ohm impedance and capability to go from 0-1 volt
anneh
Member
01-10-2007
12:42 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
does PXI-6713 have a 50 ohm impedance and capability to go from 0-1 volt?
Thanks!
0
Kudos
Message
1
of 2
(3,055 Views)
Reply
Re: does PXI-6713 have a 50 ohm impedance and capability to go from 0-1 volt
Nick_CH
NI Employee (retired)
01-10-2007
02:53 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
According with the
specification
(the help file can be download on
Analog Output Series Help (User Manual and Specifications)
The Voltage Output Impedance is 0.1 Ohms
The Output Range is +/- 10V or +/- AO ext ref.
Nick_CH
Voltage Output Specifications.JPG 13 KB
0
Kudos
Message
2
of 2
(3,053 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
