PXI
dual monitor PXI-8119
I have PXI-8119 and want to install a dual monitor I have a StarTech (DP2VGA2) that I want to use but it looks like the windows 7 driver does not support the dual monitor function, do you have driver software for the PXI-8119? or how to get dual monitors working with this system?
(5,240 Views)
You can use a second monitor on the display port using a display port to VGA converter.
-Jayk
RF R&D
(5,204 Views)
But I can only show the same image on both monitors, I wanted to split the desk top between monitors, could not find driver to support other then the single general monitor display.
(5,195 Views)
Check out this link that details how to extend monitor display.
https://support.microsoft.com/en-us/kb/976064
Let me know if that doesn't work for you.
-Jayk
RF R&D
(5,181 Views)
No help, I just went with a larger monitor, but also had to install NI video drivers s/w to change the resolution. Thanks for helping.
(5,161 Views)
