PXI
embeeded controller 8108 boot problem
Hello everey one,
I
I'm using  the embeeded controller 8108 with PXIe 1075 chassis, when i turn it on, all the led (including in the front of the embeeded controller) still off and just the led in power button is green, and the fans are running,
I tried the reset button ...without result
i'd like to know if some can give me some solution of this problem.
(4,431 Views)
hello
first step is to check the connection
then check the software is device drivers are installed and MAX is working or not then if you push the reset button then you have to assign the I.P address again then try to chek hardware
(4,403 Views)
