PXI
error -1074118650 on DMM 4070
I have an error -1074118650 when reading one tension with DMM 4070. I can I solve this problem?
Thanks.
(4,058 Views)
Bonjour,
Pourriez vous être un peu plus précis....
Avant de rentrer dans les considérations logicielles, avez-vous fait un test avec le Ni-DMM Soft Front Panel? (Dans MAX/Outils/Soft Front Panel/NI-DMM Soft Front Panel).
Si ce test est concluant,l'erreur que vous mentionnez apparaît au sortir de quelle fonction? Dans quel environnement de programmation?
Cordialement,
David DELEBECQUE
Ingénieur d'Applications
NI France
(4,049 Views)
Good afternoon,
When this error happens sometimes I must close the Labview, sometimes I
must
turnoff the PXI, because DMM with Reset and Inicialize Vi's stays with the
problem when I trying to make another measure. I use DMM for voltage and
frequency measurements. I measure DC and AC voltage. Sometimes I need to
measure 0Hz frequency when I have no signal.
This error happens with niDMMReadMultiPoint.vi.
 Nuno Rodrigues
(4,047 Views)
Hello Nuno,
To help you find where is the problem, we need some more information.
- What are the versions of : NI-DMM, LabVIEW, your operating system?
- Could you tell me if the test of the PXI-4070 from MAX (Measurement & Automation Explorer) pass correctly?
- Does this error appears systematically with your LabVIEW application?
- Do you have the same errors with the examples provided with the NI-DMM drivers?
- Does this error happened only when you have no signal in input?
- What is the exact error message returned with the error code?
Thanks!
(4,039 Views)
Good afternoon,
I want to send to you four files in attach with the problems I have. Give me an email.
My version of Labview is 7.1.
My operating system is XP Professional.
I made the test with DMM multimeter. I put 24V DC and the result was zero measured (you can see in DMM image).
This problem occurs when I try to measure AC signal (you can see in error_code image) but I had no valid signal in input.
I close and open the Labview and the problem stay.
Nuno Rodrigues
_____________________________________________
LINCIS - Non-Conventional Information Systems
Rua António Fernandes Ferreira Gomes n.114
Apartado 2169
4701-902 BRAGA - PORTUGAL
T.:+351 253 671247
F.:+351 253 671247
e-mail: nrodrigues@lincis.com
http://www.lincis.com
(4,008 Views)
