PXI
error when using data postion delay
I obtained this error when using data position delay. Can anyone please tell me the reason why I can not configure the delay to be between 0.7 and 0.8.
Possible reason(s):
Driver Status:  (Hex 0xBFFA403F) Unable to configure requested delay property given the current clock rate.
Ensure that the delay value specified is within the valid range for the frequency specified or do not configure property for delay operation.
Device: PXI1Slot2
Property: Data Position
Sample Rate: 40000000.0
Requested Value: 0.71875
Supported Values: 0.000 through 0.200, 0.300 through 0.700, 0.800 through 1.000,
Status Code: -219401
(3,085 Views)
Timothy,
The 656x devices have a limit on the available data delay values based on frequency.  Between 25MHz and 50MHz there are "holes" in the available delay range.  Above 50MHz, the full 0 to 1 data delay is valid.  If you look in the specifications installed with NI HSDIO for the NI 656x, on page 7, Figure 1, there is an illustration showing how to compute what the valid range is for the frequency of interest.
For example, at 40MHz, valid values are:
0 to 0.2
0.3 to 0.7
0.8 to 1
In the error message posted below, you tried to input a value of 0.71875 which is not within these ranges.
(3,083 Views)
