PXI
fatal error KERNEL.146640 while using DLL
Hello everyone,
I'm having a problem using a DLL with self written DLLmain. Maybe someone can tell me what is wrong.
The DLL is
// ########## DLL ################################
#include <cvirte.h>
#include <ansi_c.h>
int __stdcall DllMain (HINSTANCE hinstDLL, DWORD fdwReason, LPVOID lpvReserved)
    switch (fdwReason)
        case DLL_PROCESS_ATTACH:
            if (InitCVIRTE (hinstDLL, 0, 0) == 0)
                return 0;      // out of memory
            printf("a process attached\n");
            break;
        case DLL_PROCESS_DETACH:
            printf("a process detached\n");
            CloseCVIRTE ();
            break;
        case DLL_THREAD_ATTACH:
            printf("a thread attached\n");
            break;
        case DLL_THREAD_DETACH:
            break;
    return 1;
int __stdcall DllEntryPoint (HINSTANCE hinstDLL, DWORD fdwReason, LPVOID lpvReserved)
    // Included for compatibility with Borland
    return DllMain (hinstDLL, fdwReason, lpvReserved);
int DummyFunction(void) {
    printf("InterfaceDummy: DummyFunction called\n");
    return 0;
//##### end DLL ############################
and the program using the DLL is
#include <windows.h>
#include <cvinetv.h>
#include <ansi_c.h>
#include <cvirte.h>
#include "InterfaceDummy.h"
extern int CVIFUNC RTIsShuttingDown (void);
void CVICALLBACK SubscriberCallback(void * handle, CNVData data, void * callbackData) {
    unsigned long   nDims;
    CNVDataType     type;
    static int counter=0;
    printf("trigger: callback ");
      if (data == 0)
        return;
    CNVGetDataType (data, &type, &nDims);
      // Abort / Start case
      if (type == CNVBool && nDims == 0)  {
        char value;
        CNVGetScalarDataValue(data,CNVBool,&value);
        if (value) {
            DummyFunction();
            counter++;
  printf("%d\n",counter);
  CNVDisposeData(data);
void CVIFUNC_C RTmain (void)
    CNVSubscriber hSubscriber;
    int error;
    if (InitCVIRTE (0, 0, 0) == 0)
        return;    /* out of memory */
    Sleep(20000);
    printf("trigger: program started\n");
    DummyFunction();
    if( error = CNVCreateSubscriber("\\\\134.245.69.241\\trigger\\Trigger",SubscriberCallback,0,0,10000,0,&hSubscriber)){
        printf("trigger: error occured while creating subscriber\n");
        return;
    else
        printf("trigger: subscriber created\n");
    while (!RTIsShuttingDown () && error==0)
        Sleep (500);
    if(error = CNVDispose(hSubscriber)) {
        printf("trigger: error: ");
        printf(CNVGetErrorDescription(error));
    printf("trigger: program exited\n");
    CloseCVIRTE ();
//##### end program ############################
As long as DLLmain() is commented out everything is fine. The program runs just as expected. But when I compile the DLL with the DLLmain function and start the program, the system crashes with the output:
Fatal error KERNEL.146640: Thread stack overflow. Thread ID=95
Thread stack range =0x37F9000 - 0x37F9FFF, size 4096
current ESP = 0x37F8C58
I'm using Labwindows/CVI 8.5.0. The program runs on a NI PXI-8196 RT Controller.
Message 1 of 1
(3,453 Views)
