PXI
formatted 8187 disk partition
I am using
PXI -1042 Chassis
PXI-8187 Controller
Pxi-6289 card
for real time applications in labview 8.0
after successfully configuring the real time task , I switched to other Operating system (Windows Xp) which should be installed in our pxi system So i started to install Windows xp. I tried for several attempts to install but i failed and decided to format the C drive of the pxi system. after formating i succeeded to install windows xp but my Labview RT is not running either it is formatted also or may have some problem.
So how to Install the Labview RT now?
(3,694 Views)
Haider,
Please consult the following Knowledge Base article (KB) that outline how to dual boot Windows XP and LabVIEW Real-Time on your PXI controller.  Let me know if you have any additional questions.
Mark
NI App Software R&D
(3,674 Views)
