PXI
fpga PXI NI7831R subvi nirviExtendedMemory.vi LV2011
With LabVIEW 7.1 projects I had been using a memory subvi called nirviExtendedMemory.vi - it functions as "non-volatile" memory. That subvi is called by a 16x128block.vi. The subvis together work with LabVIEW 2011 on the host but it breaks a LabVIEW 2011 FPGA project because the "subvi 16x128block subvi is not executable".
I'm new to LabVIEW 2011 - can this be resolved in the FPGA project configuration?
John
(4,625 Views)
Accepted by topic author brokebelt
Hi John,
Can you give a little more information on the functionality you are trying to achieve?  Would it be possible to post these subVI's?
Perhaps what you are looking for is block memory.  Try right-clicking on your FPGA target and selecting New>>Memory.  Take a look at the "Memory Items" section of this article.
Best,
Jeff S.
(4,597 Views)
