PXI
fpga compilation'
I'm using PXI board in Labview FPGA. I'm a new user.
When I'm compiling even a simple program on FPGA target, it is showing error message that compilation failed as clock timing exceeds it. I made sure that it is a simple program only. But it is again encountered.
Any help on this would be appreciated.
Thank you in advance.
(5,409 Views)
Can you share any code that is showing this issue?
GCentral
(5,405 Views)
Earlier when i tried with a pulse generation it encountered this pblm. So I tried with a basic labview program.
It encounters the same pblm saying that timing exceeds the limit.
(5,400 Views)
Could you please share the code? We can take a look at it for you.
Aditya
(4,760 Views)
