PXI
generatig double pulse signal
Hello evreybody,
i'm trying to generate a signal with double pulses in which should be able to change the time interval of each pulse
t1 and t3 ( switching on intervals ) and also to change the time interval of the switching off period t2
note : all these time intervals are independet from each others and also not periodic and these three time intervals
will be in µs ( between 1µs and 10 µs )
 i have labview 7.1 and the device which i use is NI PXI-6259 M series
could you please help me with your advise, how can i generate this signal ?
thank you very much
satriany
(2,875 Views)
(2,861 Views)
