PXI
how do I change the subnet mask on the pxie-1078
we lost access to the pxie-1078 and think it's because the network subnet mask has changed on network. How do I change the subnet mask on the pxie-1078.
(2,015 Views)
You might do it in OS of your PXI Controller and not on 1078.
(1,787 Views)
  1. Log on to the computer by using the Administrator account.
  2. Click Start, point to Control Panel, and click Network Connections.
  3. Right-click the local area connection that you want to modify and then click Properties.
  4. In the This connection uses the following items box, click Internet Protocol (TCP/IP), and then click Properties. The Internet Protocol (TCP/IP) Properties dialog box appears.
  5. Continue with the steps in one of the following two sections, depending on your circumstances MyIndigoCard
(1,772 Views)
