PXI
how do I measure a second rising edge on the PXI 5152 scope
I am using the PXI 5152 and it seems to only measure the very first waveform it 'sees'. How do I measure a second or third etc. edge of a waveform? I can use the period feature and do a math function, but what about a non-clock signal. There has to be a better work around. Please help if you have experienced this.
(3,126 Views)
Hi Raid,
It sounds like you want to capture repeated waveforms using a trigger: each time a trigger condition is found, you want the hardware to grab a record. With the NI-SCOPE driver, this is called multi-record fetching, and there is an example for both LabVIEW and C that shows how to do this. The driver installs shortcuts to these examples in the Start menu: Programs » National Instruments » NI-SCOPE » Examples » (your application environment). From there, it will be straightforward to use the code in the example with your application.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,109 Views)
