I’m using NI-Digital in LabVIEW to test an I²C-based interface.
The block diagram flow is:
niDigital Initialize with Options
niDigital PPMU Configure Output Function
niDigital PPMU Configure Voltage
niDigital PPMU Configure Current Limit Range
niDigital PPMU Source
niDigital PPMU Measure (Voltage)
niDigital PPMU Measure (Current)
niDigital Load Pin Map
niDigital Load Specification Levels and Timings
niDigital Apply Levels and Timings
niDigital Load Pattern
niDigital Create Source Waveform
niDigital Write Source Waveform
niDigital Create Capture Waveform
niDigital Burst Pattern
niDigital Fetch Capture Waveform
niDigital Close.vi
In Digital Pattern Editor, the pattern runs correctly and the ACK is captured as 0,0,0.
However, when I execute the same sequence from LabVIEW, the captured data shows 1,1,1.
Are there any debug methods available as labview is not showing/receiving any error also.
