PXI
how to sample a voltage signal correctly
Dear Experts,
                     I have a slight trouble in sampling a voltage waveform,  I have measured it using an oscilloscope and know that it is a 50Hz frequency waveform, with a rms value of 137V which works out to be a peak voltage of 230V.  But when I try to acquired through my 6052E through one of my analogue input ports, I have got this unusual waveform back.  Im not sure why im not getting the correct signal, would there be some kind of sampling issues im not performing correctly?  Please advise, I have attached the simple vi and the waveform I got from the software and from the excel I tried to record to.  Thanks for your time.
Best Wishes,
Cazza
(3,386 Views)
Hi Cazza,
What signal conditionaing are you putting on the input signal?
The card you have can only accept a -10 to 10v signal.
Please can you confirm this and then we can look into the issue further.
Regards
JamesC
NIUK and Ireland
(3,365 Views)
Hi JamesC,
         Sorry about the lateness of the reply, I believe I have solved the issue as I was putting in the wrong sampling rate, I understand that the card takes -10 to 10 and I have stepped down the voltage before entering my DAQ card.  Thanks for your time.
Best Wishes,
Cazza
(3,345 Views)
