PXI
identify connector that plugs into the analog bus in HVBP on 1010 chassis
I need to connect the 4070 DMM to the high side of each of the 4 analog bus lines because the tests do not involve wire pairs but individual single pins. I need to build a 185444 like cable [DMM to HVBP] with the high sides connected and the low sides not connected. To do so, I need the p/n or nomenclature for the 8 pin rectangular connector that is the analog connection to the high voltage back plane.
Message 1 of 1
(3,161 Views)
