PXI
in max how to create simulation for pxi 1052
i want to  check my code with out conncting pxi 1052 ,,and pxi 6221 m series daq ...  in max how i want to create the virtual pxi ,and daq .....
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
(3,518 Views)
Hi Ni-xpi,
You should go in MAX, and under my system, right click on "Device and interface" then 'Create new object' and then 'NI-DAQmx simulated device'. In the M serie, you can find PXI-6221. This should allow you to test your code with a simulated device.
(3,516 Views)
