PXI
is it possible to fix ACK1 pin3 of Pxi-6534 to high impedance ? but only this pin ?
Dear all
I did a mistake in a design.
I'm working with Pxi-6534 board and i have to isolate one pin.
I would like to know if it is possible to fix only one pin to high impedance to isolate it.
This pin is the number 3 of connector 68pin  of Pxi-6534 board.
Name : ACK1 (STARTTRIGH1).
This pin is part of group1.
thank you for your answers,
Cyril
(4,077 Views)
Hello Cyril,
I haven't found anything that would allow you to do that. I believe the only solution you have would be to use an external circuitry.
Have a nice day,
M-Junior
(4,051 Views)
Hello M-Junior, Thank you for your answer. Effectively, the control lines can't be used in open collector. However, we can use this two group like extra data lines. So, I thought we could configure it like data lines : input (for 4 bits) ouptut (for the other four bits) and open collector. I haven't found anything about this possibility. so, I am going to use an external circuit. Best regards
(4,047 Views)
