PXI
main application of Pxie6363
Hi everyone
I have bought PXie 6363 and I would like to know what is the main application of this PXie. can anyone give me some sample program and application of this device ?
Also do you know if this device also works as counter input or it works as only counter output?
thanks
(5,312 Views)
All of NI's multifunction DAQ modules (X series included) have a wide range of applications.
If you search ni.com for DAQmx examples, you'll come across a variety of community examples and tutorials that explain various applications for DAQ devices, some of which should provide some example code.  In addition, if you are using LabVIEW, you can navigate to help >> find examples >> Hardware Input and Output and take a look at the shipping examples intended for use with DAQ devices like the 6363.
Best,
(5,310 Views)
