PXI
need connector detail
Need the pin out identification for 761289-16.
Please email pictures or spec. on how housing unit is assembled and wired.
(4,167 Views)
Hi balandry,
The following page contains the pin out for the 2565 which connects to the 761289-16.
https://www.ni.com/docs/en-US/bundle/pxi-2565-features/page/pxi-2565-overview.html
This is all the information that is available on our website for the 761289-16, if you need more detailed information, post back with what you need and I will check if it is available.
Scott M.
(4,146 Views)
Is it possible to get a step/iges file for 761289-16?
Thank you,
(2,168 Views)
Those are probably Phoenix connectors and you should be able to get the 3D models from Phoenix
https://stevenengineering.com/tech_support/PDFs/67_PCB-MINI-PLUG-IN-CONNECTORS.pdf
Santhosh
Soliton Technologies
(2,154 Views)
