PXI
need for resistors in cpci
does it a mandatory to place 10 ohm resistor for CPCI board . if i dont place this resistors i would have problem or not
thank you
(3,136 Views)
Hello yangero,
Welcome to the NI forums!  Before I answer your question, I am going to need some more information. Whether or not you need a resistor depends on what you are trying to do and what hardware you are using.  Our various cards have many different features, several of which may require external resistors.  If you could please let me know what your application is (e.g. voltage measurement, digital generation, etc), the device number you are using (e.g. PXI-6251), what settings you are using (screenshots could help), and where you see that you may need this resistor, I will be able to help you more effectively.
Neal M.
Applications Engineering       National Instruments        www.ni.com/support
(3,120 Views)
