PXI
ni can, ni xnet
Hello All,
I am using NI-PXIe-1071 with NI-PXIe-8821 as my chassis and one CAN module NI-PXI 8513 which is a 2 port CAN module. Now am trying to communicate with ECU through CAN module using KWP2000 protocol. In NI MAX, there is no problem i can able to communicate but through my labview code I could not, an error has been generated. I have attached the error code kindly tell me suggestions.
Thanks in advance.
(4,125 Views)
Hello bharathiraj87!
The error might occur  when there's no response from ECU. Try to fix the coercion dots and check the cables
(2,697 Views)
