PXI
ni
hi,
We are implementing a CANopen device in our system and I am trying to implement this functionality in Veristand 2012. I have the NI PXI-8531. I connect the NI PXI-8531 via a NI CAN cable to a CAN Breakout box. The NI PXI-8531 modul is inserted in PXIe-1078 chassis. we are using a NI-PXIe-8135 controller. I have a motor that is connected to CAN Breakout box with a CAN cable. The idea is to control the motor via CANopen communication.
I'm not able to see the NI PXI-8531 modul in NIVS's system explorer. What i have to do to observe the NI PXI-8531 in NIVS's system explorer? Do you have any example or helpful links that explains the necessary steps to get data from NI PXI-8531?
Michel
Message 1 of 1
(5,560 Views)
