PXI
niDMM call setting not allowed
Our company introduced PXI-1033 and NI40470 to improve the voltage measurement accuracy two years ago. During the normal production, after testing for several hundred thousand times(~200,000~2million), it will alarm: "niDMM call setting not allowed". each time, we need reboot the computer to fix this problem. It caused a lot of engineering work and machine downtime. Regarding to this problem, is there any solution to reduce the alarm frequency or eliminate it?
(5,331 Views)
You need to supply a lot more information if you want any help.
What changed right before the errors started happening?  Software just doesn't stop working after 2 years.
How are you calling the DMM?  How are you handling references?  What software are you using?  What setting are you not allowed to make when you get this error?
Any code you can supply will help the debugging process.
GCentral
(5,324 Views)
