PXI
on off Tempurature control with hysteresis
Hello Everybody,
i'm about to controll the temperature of a  heater between two values upper limt an lower limit  i finished the VI  to measure  the  actual value and  also  to switch on and switch off the realy which is connected to the heater. i need to produce   hysteresis in which i can compare my real value with the upper limit and lower limit  and get the output signal only when the actuall value between these two values.
i want to ask if there is special VI which makes this funktion dierctly
i have labview version 7.1
and PXI 4351
thank you very much
(3,713 Views)
Are you using DIO lines onboard 4351 for switching on/off heater??
If u are, just acquire value, use a 'in range?' function from comparisons tools>.functions palette for checking for hi gh and low limit.
Connect the boolean output of this function to a case structure and perform high/Low Digital output on DIO lines inside appropriate case.
Hope this helps
regards
Dev
(3,706 Views)
Hello devchander,
Thank you for replaying
no i use  NI PXI 2565 general  purpose relay switch to switch on/off the heater and i produced the required DAQmax which control this relay as a digital output signal
i use the PXI 4351 only to measure the temperature
do you have any suggestions
thank you
Satriany
(3,704 Views)
Yes my suggestion is use the same programming logic I have explained in previous post.
Just put the code for switching on/of relays on PXI 2565 inside the appropriate case
(3,694 Views)
