02-23-2009 05:10 PM - edited 02-23-2009 05:11 PM
I have a comptuer that is about 3-4 months old
ITs a dell optiplex 755
I just purchased a 195315 pci express card.
This is for reading a ni pxi 1042
Connected to that are some stepper controller units.
upon boot of the PC, i get
"Alert Error initializing PCI express slot 4"
This is both with and without the PXI device connected.
The card is turned on in the bios.
We just paid a lot of money for these system.
It would be nice to get it to work and any help is appreciated.
someone else seemed to have the same problem.
I didnt see how it was resolved.
http://forums.ni.com/ni/board/message?board.id=270&thread.id=6339&view=by_date_ascending&page=2
02-23-2009 05:34 PM - edited 02-23-2009 05:35 PM
on phone with ni now
they said it is on the list of known computers this card shoudl work with
http://zone.ni.com/devzone/cda/tut/p/id/5022
I have to say, ive never heard of a card not working in a slot its desiged for.\
doing bios update a09 to a012
02-23-2009 06:11 PM
bios maintaince log reports
out of range chassis intrusion
well, remind me and ill post a solution if anyone wants it
Have been on the phone a few times with ni and no luck yet
02-24-2009 04:03 PM
Dear JimmyinCT,
Did your issue get resolved?
Sincerely,
Sammy Z.
02-24-2009 06:20 PM
thanks for checking in sammy.
no, this is not really resolved yet
im willing to do whatever, buy new hardware or even a new comptuer.
we have the ni sales guy coming by later in the week.
it would be nice to fix what we have if it can be done.
the optixplex 755 is supposed to work with this card. ni pcie-8361
02-25-2009 01:33 PM
Dear Jimmy,
I read all the way through the forum that you had mentioned. There are a lot of good information that was shared.
Have you made sure that you're doing everything that is suggested on that forum?
For example, are you making sure that your PC is turned off when you power on the pxi chassis, then powering the PC?
What is the module that is being mailed to you?
Also, I realize that you have spend a huge amount of money on your equipment and I'd like to get your issue resolved ASAP. Please share your phone number if you'd like so I can contact you in case your issue is not resolved.
Sammy Z.02-26-2009 08:52 AM
While the other thread sounds a lot like your issue, you said that it didn't matter if the PXI system was connected. If you're getting this message with the PXI system powered then it is probably something else.
Can you clarify whether "connected" also means powered (as Sammy asked), and tell me what are the LEDs on the MXI card in the 1042 chassis doing? Have you ever seen this system work, either on this or another computer?
- Robert
02-26-2009 10:00 AM - edited 02-26-2009 10:01 AM
ok, we are good now.
it was a combination of problems
one is that the power on the pxi had to be turned on while it was plugged in.
I had done this orignally.
Also, it was conflicting iwth some raid controller which was easy disabled.
I dont think this controller is part of the typical optiplex but rather something that uconn puts in all univeristy pcs to make it data mirror.
thanks guys!!
03-13-2009 02:37 PM
Can I get more details? I have the same problem. BIOS complains during boot. I did not even try installing drivers or plugging it in (into PXI chassis).
I have 2 hard disks in my PC installed in RAID configuration, this is how it came from DELL.
thanks
CTK
03-13-2009 02:48 PM
i had a few problems
I had the chassis power on from the start as i had read the other persons post before i made mine.
i went into the bios and was shutting integrated devices on and off and it finally started working.
What odd is when i put all the devices back on, it kept working.
It dosent make sense.
I honestly dont care enough to look more into this now. sorry..
I ended up just using a microcontroller for my design anyway.
