PXI
programaticaly finding the Slot information device information, device number of PXI card
I need to find the slot position,device number,device name of the PXI card assigned. programmaticallyhow do acheive it .
I am using LAb veiw 7.0 and Traditonal way of NI DAQ programming for LAb veiw 7.0 RT does not support NIQMax.
Suresh Thangappan
(3,158 Views)
Suresh T,
There is a KnowledgeBase here on ni.com that goes into great detail about programmatic slot and device number detection. You can find that device by following this link:
Programmatic PXI Slot Detection
Please read over that document (and the related links at the bottom of the page if they apply) and see if that is able to clarify your issue. If that solves your issue, then great. However, if you still have questions after reading over the KnowledgeBase, please make another post with some additional questions, so that this forum can assist you in resolving your issue.
Best of luck with your application.
Jed R.
(3,141 Views)
