03-10-2009 05:19 AM
hi i have both pxi-1441 and 1409 acquisition cards
a composite source i use can be captured by the 1411 but not by the 1409. i have set up the channel and sync as required but this makes no odds.
any advice?
03-11-2009 08:24 AM
Hi Slugger,
Hope you are well.
You said you cannot capture using the 1409 isn't working. in what way is this not working? Are you receiving errors?
I have a KB for you that may help you in your quest How to Configure NI-IMAQ and the PXI/PCI-1408 or 1409 IMAQ Hardware to Acquire StillColor Images?
Are you trying to configure this in MAX or LabVIEW?
