PXI
pxi-2568 connecting cable
Dear all,
I bought in the past a cable (779956-01, 62 pin female to female DSUB), for connecting the PXI-2568 to my application.
I noted that this cable is actually made with four separate cables, between the two DSUB connectors.
I know that the two connectors are 1:1 cabled; but is there any schematic (or similar) which shows me how the 31 relays of the module are "splitted" into these four cables (i.e. the first cable contains CH0 to CH7 relay, etc.)?
Thank you for your help and Best Regards
Stefano
(3,426 Views)
Hi Stefano,
I'm sorry but there aren't any documents that reported information about your question.
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
(3,410 Views)
