PXI
pxi-5421 and ground
I want to use PXI-5421, arbitrary waveform generator and external function generator made from Agilent.
Two signals from them should have the common ground.
I found the chasis ground on the back panel of both PXI module and Agilent.
Can I connect each other for my purpose? or other considerations?
In addition, DAQmx (AD, DA, DIO) and signal generator in PXI module has the common ground without futher consideration?
labmaster.
Message 1 of 1
(3,403 Views)
