PXI
pxi-6221 error: -88301
Hello Have a Problem with my PXI. The PXI was configurated by NI. All function of the cards was good. Whit M&A. I installed LabVIEW 2009, after this installation not found the DAQ Assistant in LabVIEW. i reload the Driver set June 2011, for Data Acquisition --> DAQmx 9.3.0 support LV 2009 Now i found the DAQ Assistant in LV 2009. But the DAQ Assistant do not found my Card PXI-6221. The other Boards (PXI-5114 and PXI-2566) is the function ok. My hole configuration: Chassis PXIe-1071 CPU PXIe-8101 PXI-6221 PXI-5114 PXI-2566 Now i look in M&A, the show me the three cards. I test them whit the self test. 5114; ok 2566; ok 6221 fail error:-88302 who can help me?? i think its a setting problem. Regards walym
(3,354 Views)
Hi walyM,
This issue is most likely caused by a corruption to the DAQmx driver.  You can repair the driver from your initial installation or if the installation is corrupt you may have to download the DAQmx 9.3 drivers from our website by clicking here. Running the installation should give the option to repair. The specific information is also found in the Knowledge Base found here.
Andy K.
(3,312 Views)
