PXI
pxi-8119 64bit
I have a PXI-8119 and want to load windows-7 64 bit op-system, what drivers do I need to install?
(5,366 Views)
For the controller, you will need the PXI Platform Services driver: http://www.ni.com/download/pxi-platform-services-14.0/4897/en/
Beyond that, I am assuming you have other PXI modules in your PXI chassis. You will have to install drivers that correspond to those modules. You can view which driver is required for each module in the Data Sheet for that particular module.
Kevin S
(5,350 Views)
