PXI
pxi 8195 system state: unconfigured
Dear Community,
on start up the real time pc pxi 1042 with a pxi 8195 controller don´t start the RT-Model. The screen shows the following message:
(the pc doesn´t have a operating system because it is only used for the RT-Model)
Transferring control to user program.
LabVIEW RT Boot Loader
(C) Copyright 2002-2005 National Instruments Corporation
LabVIEW Real-Time  Single-Core Kernel
MAX system identification name: Unspecified
Initializing network...
Device 1 - MAC address: xx:xx:xx:xx:xx:xx - 0.0.0.0 (primary)
System state: Unconfigured
I hope someone of you can help me
(6,098 Views)
Accepted by topic author AR85
First of all, welcome to NI Forum!
You can find a detailed guide how to setup your PXI system with your Realtime system here:
RealTime PXI System Initial Configuration and Software Installation     http://www.ni.com/white-paper/12871/en/
That screen your see is just a console which returns events on the pxi. In your case it says your pxi is unconfigured.
You can't create mouse and keyboard events on a Realtime system because that would mean your system is no more deterministic.
Therefor all configuration and programming is done on a host pc, which connects to the pxi and deploys your programming.
(6,082 Views)
Hi JohannesM,
Thank you for your reply, my system is back Smiley Happy!
(6,071 Views)
