PXI
pxi not detected under max
Hi...
I have aPXI 1000B chassis with 8156B controller, i am trying to make the pxi get detected under MAX for 1 month now... still no result... i don know what the problem is...
(4,580 Views)
Need to know:  What version of Windows (XP, 7?), what version of LabVIEW, what version of MAX, what PXI controller.  Are you setting the controller up for the first time (i.e. it has never had LabVIEW RT installed on it)?  What happens when you turn on the PXI, with the controller connected to a display -- does it boot to anything (e.g. to Windows, to a Real-Time OS, and if so, to what version)?
(4,575 Views)
i am using windows xp. the labview version is 7.1 with a 7.1 real time. the max version is 3.3 and the controller is 8156B with 1000B chassis. the pxi doesnot boot into anything, but when i connect a vga port the boot screen look like the one in photo i have attached.
(4,517 Views)
