PXI
"niSwitch Abort Scan.vi" takes a lot of time in scanning mode
Following example is based on
C:\Program Files (x86)\National Instruments\LabVIEW 2017\examples\instr\niSwitch\Switch - Scanning - Software Scanning (NI-SWITCH).viniSwitch.png
Environment Information
  • LabVIEW 2017
  • niSwitch 17.0
  • PXIe-8821 + PXIe-1078
  • PXIe-8821 + PXIe-1082
  • PXI-2567
  • ScanList: ch0->com0
I have a question why "niSwitch Abort Scan.vi" takes a lot of time under scanning.
When "Wait Between START and ABORT" was set to 0, the VI took about 16msec.
When I increased the parameter to 50msec, it took 1.6msec, error "-1074126842" returned.
I guess under scanning, the VI takes a lot of time. But it too long...
Is this based on my coding problem or hardware/driver?
Can I decrease the process time?
At above settings, the scan should finish within 1-5msec I believe. When I set "Wait Between START and ABORT" to 0, the VI took 16msec but when I set the parameter 15msec, the situation wasn't changed. From this result, the scanning was not finished, it took over 15msec.
Does scanning require so many overhead?
FYI: Error "-1074126842"
"The switch module is currently in scanning mode, and the operation cannot be performed at this time."
<<Under Scanning, no error but takes ~16msec>>
<<Scanning stopped, fast but error returned>>
Certified LabVIEW Developer
GCentral
(2,536 Views)
GCentral
(2,528 Views)
Accepted by topic author Tepig
We concluded that NI Switch driver doesn't work fast.
It seems that it internally does some module/system check to guarantee the module health.
There is no way to make it fast.
GCentral
(2,370 Views)
