PXI
scxi communication with DAQmx
I have a problem to communicate with an SCXI-1540 module.
In MAX I see the module and I've set in the "Data neighborhood" a NI-DAQmx task to reed the volts on the input.
I see a standard value of 5,38V even if I change the input.
Did I miss a setting?
Message 1 of 22
(6,652 Views)
Can you provide us with some more information about the issue you are encountering?
The things I'm most interested in are:
- A MAX Report that shows the software that is installed:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
- The explicit task you're using:
http://digital.ni.com/public.nsf/allkb/0E0D3D7C4AA8903886256B29000C9D5A?OpenDocument
- Screenshots of the steps you're taking:
This will show me exactly how we should try to reproduce it.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 22
(6,607 Views)
Sorry for the late answer.
In attachment you can find the requested information.
Thanks in advance.
Kind regards,
Filip
Message 3 of 22
(6,566 Views)
Hello Fluppe,
I was quite surprised to see only a USB-6009 showing up in MAX and no mentioning of an SCXI chassis.
How does your system set-up look like? (what hardware do you have, how is it connected with eachother,...)
Kind Regards,
Message 4 of 22
(6,556 Views)
Hi people
I have a similiar problem, with scxi-1000 and scxi-1520 and scxi-1600.
A few months ago I worked with it and it works good.
Some days ago, I tryed to connect it again but it detects the scxi-1000 but never detects the other modules.
I have LB2010 and same Max.
Why this happend? I try in other pc and gives the same error.
I tryed to add manually the configuration for the boards, but nothing.
Can someone help me with this problem?
Best regards
CPalha
Message 5 of 22
(6,444 Views)
Which OS Version and DAQmx version are you using?
Kind Regards,
Message 6 of 22
(6,430 Views)
I'm mentioning this because the SCXI-1600 is not supported under all OS-versions (only under 64 bit):
http://digital.ni.com/public.nsf/allkb/678CCC14FEA8F8CE8625743400680F8D
So please also provide me with the OS version you're using.
Kind Regards,
Message 7 of 22
(6,427 Views)
Hi
Strange is that the equipement works with same system some months ago.
After this time I dont change my OS.
Below is Daq version and OS version
Best regards
CPalha
Message 8 of 22
(6,423 Views)
Hello cpalha,
I think you might have misunderstood me:
I asked for the DAQmx version, not the MAX version.
An easy way to retrieve your NI software versions is the following approach:
Kind Regards,
Message 9 of 22
(6,401 Views)
hi
Is this file?
Best
CPalha
Message 10 of 22
(6,398 Views)
