PXI
selft test failure PXI-6562
I tried to run a self test from MAX to see if the PXI-6562 is functioning properly. I received the following error
Error-239022 occurred at Self Test
Possible Reason(s):
Internal Hardware Error occurred in MIG hardware.
What does that mean? How can I get my hardware to self test and communicate with the rest of the system?
(3,901 Views)
Hi what's an...
I notice you have filed a service request and will allow the Applications Engineer to work with you on this issue.
Please post the resolution once it is reached.  Thanks!
Chad AE
(3,883 Views)
