PXI
sensitivity for PXI SMU
How can I configurate the pxi4132 to the best sensitivity - 10pA to current measures in the 10uA of range?
(6,190 Views)
Accepted by topic author Seixas
According specifications manual when you are using the 10 uA range you are using the 10pA sensitivity, but the accurracy is (0,028% + 1 nA).
regards,
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(6,177 Views)
In your manual is wrote: "For instance, on the 10 μA current measurement range, you can typically achieve 100 pA sensitivity at up to 1000 readings per second."
I understand this is not true. Is true for 10uA currente measurement range, we have 900pA sensitivity...
(6,174 Views)
Dear Abel,
How do you configure the smu PXI-4130 to work by supplying 5V with 1.5A through the CH0 or CH1 output channel using the auxiliary APS-4100 (12V output)?
Seixas
(2,903 Views)
