PXI
sine sweept wave output DAQMx(PXI-4461)
i want generate the sine sweep signal and send this output through PXI4461,
.(the in built sine sweep function of sound and vibration toolkit is not smooth sweep )
the inputs for sine sweep generation are low frequency ,highest frequency of sweep time to sweep, sweep type(Log or Linear sweep rate ) and last Sweep rate.
I can generate this function in Labview with hardware ,but i canot through it with 4461 hardware ,
kindly help me.
thanks to all,
(3,623 Views)
Can you tell us what is the problem you are facing in generating the output through 4461 card.
Hardik Asawa
(3,609 Views)
thanks for help,
i wanted to generate sine sweep signal with formula given below,
Y(t)=sin{(2*pi*[(1/2)*(f2-f1)/t2)*t+f1]*t}
where f2 is final frequency,
f1 is lowest frequency,
t1 starting time t2 ending time,
t  elapsed time.
 above sine sweep
for the above equation i want to generate the out put signal and also read that signal throug above harware.
the sampling frequency i have taken is f2*10.
the data of N =1024,
 any suggestion welcome ,
thank you .
(3,603 Views)
