PXI
supported sessions NI-TClk
I'm using NI-TClk to synchronize NI5421 generators using C. When I run the program with "live" with the hardware connected it works just fine. Though, when I try to use it in simulated mode I get the error code -25002 and the extended error info gives:
"NI-TClk does not support the specified session
Make sure that the sessions you pass to NI-TClk are supported by NI-TClk."
So, where do I find info of what sessions NI-TClk support? Or does anyone have another idea of the difference between simulated and non-simulated mode for NI-TClk?
Regards
Fred Niemelä
System engineer
Saab Aerotech
(3,282 Views)
Well, thanks anyway 😉
(3,235 Views)
