PXI
sweep power with PXIe5630
hi,
I'm trying to make a sweep power on my PXIe 5630 (VNA)to measure magnitude phase and I'm not finding the solution ! This VNA is supposed to have the same option as "classical VNA" I used before that's why I'm little bit supprised by not finding it.
How can I handle this?
I'm open for every solution that could help.
Ossan
Message 1 of 9
(7,140 Views)
Hello GhostCole,
I sent you a private message.
Wan L
http://www.ni.com/support
Message 2 of 9
(7,111 Views)
Hi GhostCole,
Using the VNA Soft Front Panel, choose the Sweep -> Power Sweep
Then go to Power menu then input the required settings.
Or by using a sample VI: niVNA_PowerSweep.vi
James
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
Message 3 of 9
(7,102 Views)
Thanks James,
I tried it but it seems like I don`t have those options on my VNA ( I'm using the PXIe5630 by the way)
Any other solution ?
Regards
Ossan K.
Message 4 of 9
(7,094 Views)
What version of NI VNA soft front panel are you using?
Try to update if not the latest: http://www.ni.com/download/ni-vna-2.0.1/3784/en/
If still the Sweep Menu is not available in the soft front panel, you can use the sample VI attached on the previous message.
Thanks.
James
Message 5 of 9
(7,208 Views)
I have the 2.0.1 version of NI VNA. I download and update it as suggested, but nothing changed ! Same problem, only frequence seems to be sweepable ! The vi joined on the previous mail, specified a configuration or parameter problem and I really don`t know what to do !
Ossan
Message 6 of 9
(7,051 Views)
Hello Ossan,
Judging from this help document, it seems like the power sweep is supported only on the 5632:
http://zone.ni.com/reference/en-XX/help/373153C-01/vnaviref/nivna_configure_sweep/
The NI VNA shipping example for doing a power sweep only has 5632 listed as a supported device.
The specs sheet of the 5630 does not mention power sweep where as the one for the 5632 does.
All these things lead me to believe that device does not support power sweep
Wan L
Message 7 of 9
(7,040 Views)
I'm confused ! A new generation "VNA" not supporting power sweep that all old versions could ???
Message 8 of 9
(7,034 Views)
Hello GhostCole,
I'm not sure what you mean by new generation of VNA and which older versions you are referring to. I was trying to explain that the 5630 does not support power sweep but the 5632 does. This is explain in the help file that I linked in my previous post.
Wan L
Message 9 of 9
(6,960 Views)
