PXI
switching between terminal blocks with one module
Issue with New TB-4300 Terminal Block Not Being Recognized by NI PXIe-4300 Module
Hi everyone,
I'm currently using an NI PXIe-4300 module with a TB-4300 terminal block. My original terminal block works fine, but I'm having trouble with a new TB-4300 terminal block. When I connect the new terminal block, it isn't recognized.
i have 2 test chambers and im trying to make it so a technician can just switch the terminal blocks for each room
Message 1 of 1
(303 Views)
