PXI
synchronize NI PXIe-5105 and NI PXIe-5160 scope cards and set both scope cards to the same sample rate
I have two NI PXIe-5105 scope cards and one NI PXIe-5160 scope cards.  Signals are triggered measurement channels on one of the NI PXIe-5105, the other two scope cards should synchronized to the trigger signal.
I have two problems:
1) Unable to route the trigger signal from the measurement channel of the NI PXIe-5105 to the backplane.
2) Unable to program the sample rate of NI PXIe-5160 to match the sample rate of NI PXIe-5105.
(2,639 Views)
Hi Icefan,
Could you provide more information about your complete system layout including all hardware in your chassis? Also, attaching your code to this will help see how you are trying to implement this functionality.
Hunter D.
(2,617 Views)
