PXI
synchronize flex rios
I need to synchronize to flexRIO FPGA devices (7965) that are on the same chasis.
The nearest I can figure out is that one uses the TClk palette, but these dont seem
to want to play nice with the FPGA nodes.
Plus, the TClk VIs that I have say that the reference clock for them is the 10MHz
clock of the PXI backplane.  I have a PXIe and it has an additional 100MHz clock.
How would I go about making this the reference clk??
Any help very much appreciated.
Thanks.
(3,372 Views)
Can you provide further details on your application?  Which FlexRIO adapter module are you using?  What type of measurement are you trying to synchronize?  What are the clock and trigger sources?
-RB
(3,353 Views)
