PXI
tclk awg digitizer example
I would like to try the example attached as .gif (found that on http://zone.ni.com/devzone/cda/tut/p/id/3675) . I have tried the other example ni_tclk_awg_dig_exx.zip found on http://zone.ni.com/devzone/cda/epd/p/id/5029. I had some problems with this one,so want to try the example attached as .gif
Regards
kmh
(3,166 Views)
Hi there,
I'm a bit confused!  When you said you had some problems, did you get errors?  Incorrect values back?
The picture you have attached is very small and does not show enough detail for me to decifer.  Could you repost with some more information.
What you are trying to do, what error codes you are getting and what cards you are trying to use.
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,153 Views)
