PXI
total memory of all waveforms exceeds the allocated amount of memory on the FPGA
I am using the niRFSG Allocate Arb waveform.vi to bring in a 6G waveform file.
 I am getting errors such as:  total memory of all waveforms exceeds the allocated amount of memory on the FPGA.
 Is there a way to adjust the FPGA memory on the PXI 5646 to accommodate the 6G waveform data file?
 Here is a setup
(2,828 Views)
Hi cosburn,
I don't think you are breaking up the waveform into enough smaller chunks to fit into memory.  You can check the total size of the arb memory on the PXIe-5646 using the property Arb:Memory Size (http://zone.ni.com/reference/en-XX/help/371025N-01/rfsgproperties/cnirfsg/).  Make sure that the waveform you are trying to allocate to memory is smaller than this size as discussed in this document: http://zone.ni.com/reference/en-XX/help/371025P-01/rfsg/streaming_waveform_data/.
(2,795 Views)
Hi Luke,
I have not considered breaking up the size of the waveform.  That makes good sense considering the RAM is 512K X 2 and is probably filling up while leaving the remainder unaccounted.
Your response provides me with some great direction to fix this issue.
thanks
Cosburn
(2,775 Views)
