PXI
trigger for ni pxi5122
i will mesure y,u,v independently and i will generate an external trigger for ni pxi 5122.
have you any idea how  i can see a video line using labview and external trigger and video(ch0)?
Message 11 of 13
(2,561 Views)
If you are looking to just acquire 1 line of video you will need to perform an acquisition at full sample rate for the appropriate line time (which will depend on the HD signal you are acquiring). Your external circuit will need to produce a trigger pulse when the appropriate line is detected. The acquired data could then be viewed with a graph indicator. Just bear in mind that with some HD signals that the Y signal bandwidth can be up to 30 MHz and the 5122 has 100 MHz sample rate so only 3 samples per cycle of that Burst block, this may not be enough for a very accurate measurement of the luma bandwidth so you might need to perform a number of acquisitions over a number of frames and average the measurement for a better measurement.
BR,
Nick
Message 12 of 13
(2,560 Views)
thank you 🙂
Message 13 of 13
(2,557 Views)
