PXI
unable to configure Labview RT on NI PXI 8187 controller
(3,466 Views)
I had the same problem...
Have you installed your System on a NTFS-Partition? Labview RT needs a FAT32-Partition. You have to check by booting in windows to see if the file system is FAT 32. I changed the typ of the partition with Partition Magic (Program to create new Partitions...).. After I did this, it works without problems
Good luck and best regards,
Thomas
(3,449 Views)
Hello.
Thomas, you are exactly correct. zalmay check this post out and please inform us of any updates. Thanks a lot.
(3,441 Views)
